Subject: Re: More than 16 enumerations mbbi / mbbo
To: <[email protected]>
Date: Thu, 26 Jul 2012 14:04:59 +0200
On Thursday, July 26, 2012, Hinko Kocevar wrote:
> While developing writing Asyn device driver support for our products
> running on Linux OS, we were faced with the need to support more than 16
> enumeration values that are to be represented using mbbi / mbbo records.
> I'm looking for solutions to this problem. We are trying to stay within
> EPICS base provided record types as much as possible, but we have no
> problems to include additional EPICS extensions to out soft IOC in order
> to gain record support. Last resort would be to provide a new record
> type.
Writing a new record type with, say, 32 choices based on the existing 16-
choices versions wouldn't be hard. The problem is that the result won't be
very useful because CA (Channel Access) limits the number of choices for
type DBR_XXX_ENUM to 16 which is hard coded in the protocol (see
db_access.h). So, for instance, a menu button in an operator panel would not
see all 32 choices but only the first 16; and so on.
A possible work-around would be to somehow split the choices into smaller
(related) groups, then provide a 'master' mbbi/o for the choice of the
group, and separate mbbi/o for chosing inside the groups.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Prev: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Next: Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
