Subject: Waveform read problems
To: [email protected]
Date: Fri, 27 Jul 2012 14:53:01 -0700 (PDT)
Hey Everyone,
I'm using Asyn to create a driver for the Agilent E5071C Network analyzer and am trying to create a working waveform record to readout the analyzer traces. The output of the analyzer is a list of ASCII values separated by commas. For instance, :SENS1:FREQ:DATA? returns the frequency values where the power was measured in Hz. The output is:+5.00000000000E+008,+5.05000000000E+008,+5.10000000000E+008,+5.15000000000E+008,+5.20000000000E+008,+5.25000000000E+008, ... I'm able to communicate with the analyzer, however I create a Segmentation violation when processing waveform records to store this array.
epics> dbtr AGE5071C:FREQ
ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
BKPT: 00            BUSY: 0             DESC: Frequency Series Hz
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
2012/07/27 14:12:12.823 DTYP: AGE5071C      EGU: Hz             EVNT: 0             FLNK:CONSTANT 0
10.95.101.61:5025 write 18
:SEFTVL: DOUBLE        HASH: 0             HOPR: 0
NS1INP:GPIB_IO #L1 A0 @9                   LCNT: 0             LOPR: 0
:FREMPST: Always        NAME: AGE5071C:FREQ NELM: 10000         NORD: 0
Q:DANSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 1             PHAS: 0
TA?PINI: NO            PREC: 0             PRIO: LOW           PROC: 0
\n
PUTF: 0             RARM: 0             RPRO: 0             SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       STAT: UDF           TIME: <undefined>
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
VAL: (nil)
epics> 2012/07/27 14:12:12.825 10.95.101.61:5025 read 2048
2012/07/27 14:12:12.825 10.95.101.61:5025 read 1972
000000E+009,+1.01500000000E+009,+1.02000000000E+009,+1.02500000000E+009,+1.03000000000E+009,+1.03500000000E+009,+1.04000
Segmentation fault
I'm defining the gpibCMD as:
{&DSET_WF, GPIBREAD, IB_Q_HIGH, ":SENS1:FREQ:DATA?", NULL, 0, 32000, readWF, 0, 0, NULL, NULL, NULL},
and the custom convert routine I'm using is:
// WF read routine for AGE5071C
static int readWF(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) {
  printf("%s","TEST****************************************");
  struct waveformRecord *pwf=(struct waveformRecord *)pdpvt->precord;
  asynUser *pasynUser = pdpvt->pasynUser;
  double* value = (double *)pwf->bptr;
  double data;
  int n;
  char* buffer = "\0";
  pwf->nord=0;
  strcpy(buffer,pdpvt->msg);
  while ((pwf->nord < pwf->nelm) && sscanf(buffer,"%lE,%n",&data,&n)==1) {
    memcpy(value+pwf->nord,&data,sizeof(double));
    pwf->nord++;
    buffer+=n;
    asynPrint(pasynUser,ASYN_TRACE_FLOW,"(NORD,VAL) : (%i,%E)\n",pwf->nord,data);
  if (pwf->nord == 0) return -1;
  return 0;
Since none of my error messages are printed I conclude the pdpvt->msg array is being overfilled somehow before my convert routine is even processed. I'm really not sure how to debug this since everything that I've written seems to work fine. The debug messages reveal no problems until the Segmentation violation occurs. I also don't understand why the reads can only handle a maximum of 2048 characters at a time. If anyone has experience writing device support for a waveform record your advice would be very helpful. Thanks.
Andrew
RE: Waveform read problems Mark Rivers
Prev: Re: More than 16 enumerations mbbi / mbbo Martin Konrad
Next: RE: Waveform read problems Mark Rivers
Prev: EPICS and EtherChannel Shalafi
