Subject: Re: More than 16 enumerations mbbi / mbbo
To: [email protected]
Date: Fri, 27 Jul 2012 19:50:44 +0200
Hi Hinko,
> If this record is just for displaying information to the user though you can
> make use of it;
If you only need it to display the name of the selected channel you can
also use a stringout record for each state. These stringout records can
be triggered via a set of mbbi records (each with a calc record in front
of them that picks the right input value range, e.g. 33 to 48). Only one
stringout record fires at a time. All stringout records send their data
to a single stringin which can be used to display the state with a
single record on the OPI.
Unfortunately this approach does not work for output...
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
More than 16 enumerations mbbi / mbbo Hinko Kocevar
Re: More than 16 enumerations mbbi / mbbo Benjamin Franksen
Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Re: More than 16 enumerations mbbi / mbbo Andrew Johnson
Prev: EPICS and EtherChannel Shalafi
Next: Waveform read problems apwagner
Prev: Re: More than 16 enumerations mbbi / mbbo Andrew Johnson
Next: waveform display John Dobbins
