Subject: Re: More than 16 enumerations mbbi / mbbo
To: [email protected]
Date: Thu, 26 Jul 2012 10:26:56 -0500
Hi Hinko,
On 2012-07-26 Hinko Kocevar wrote:
> >> Can it be 'undefined'?
> > Reserve yet one more choice for this. Or: set the UDF field of a record
> > e.g. via db link from another record. If you also have DISS=INVALID you
> > have a good idication of an undefined state.
There is an "undefined" state which is what you get if the integer value in
the VAL field is out of range, but you can't select this from an OPI menu
button, so Benjamin's suggestion is sensible if this is intended for input
from the user (although rather than "undefined" I would probably use another
status string that says something like "use other menu").
If this record is just for displaying information to the user though you can
make use of it; put the same value in both of your mbbi records and set their
DTYP to "Raw Soft Channel" then set each xxVL field to the value that the
associated xxST field represents.  The record that does not have a matching
xxVL value will appear in the undefined state, and you don't need to do any
calculations to get the values to put into the mbbi records.
However if you're using this as an output it might be simpler to just use an
aSub record and do the value to string conversion in C code...
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: More than 16 enumerations mbbi / mbbo Martin Konrad
More than 16 enumerations mbbi / mbbo Hinko Kocevar
Re: More than 16 enumerations mbbi / mbbo Benjamin Franksen
Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Prev: Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Next: RE: asynPortDriver Szalata, Zenon M.
Next: Re: More than 16 enumerations mbbi / mbbo Martin Konrad
