Subject: Re: Waveform read problems
To: [email protected]
Cc: "[email protected] tech-talk" <[email protected]>
Date: Mon, 30 Jul 2012 10:26:56 -0700
I put together a simple StreamDevice/ASYN application and a small python script to provide a dummy 'instrument'.   The instrument provides 30000 values on demand.
Things seem to work as expected.  Here's the output from the final command of the startup script:
dbpr "wchk:1:Wave"
ASG:                BUSY: 0             DESC: Read a long waveform
DISA: 0             DISP: 0             DISV: 1             NAME: wchk:1:Wave
NORD: 30000         SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL: 0x0
As you can see, the IOC has successfully read 30000 double values from the instrument.
Andrew -- perhaps you can massage the attached application a little to match the commands of your hardware and see if things work for you as well?
Attachment: wchk.tgz
Description: Binary data
Eric Norum
[email protected]
Re: Waveform read problems apwagner
Prev: Re: seq_pvPut() Bradley Pietrzak
Next: Re: Waveform read problems apwagner
Prev: Re: Waveform read problems Eric Norum
