1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform read problems
To: Eric Norum <[email protected]>
Cc: "[email protected] tech-talk" <[email protected]>
Date: Mon, 30 Jul 2012 13:57:42 -0700 (PDT)
Hey guys,
Thanks for all your help and advice. Using gdb I found my problem was not assigning the appropriate amount of memory to copy the record msg char* into a buffer char*. I fixed this by just accessing the record msg directly without copying it. Attached below is the custom conversion routine I found works well and reliably.
 // WF read routine for AGE5071C, converts Hz to MHz for P1==1
static int readWF(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) {
  struct waveformRecord *pwf=(struct waveformRecord *)pdpvt->precord;
  asynUser *pasynUser = pdpvt->pasynUser;
  double* value = (double *)pwf->bptr;
  double data;
  int n;
  pwf->nord=0;
  while ((pwf->nord < pwf->nelm) && sscanf(pdpvt->msg,"%lE,%n",&data,&n)==1) {
    if (P1==1) data/=1E6;
    memcpy(value+pwf->nord,&data,sizeof(double));
    pwf->nord++;
    pdpvt->msg+=n;
    asynPrint(pasynUser,ASYN_TRACE_FLOW,"(NORD,VAL) : (%i,%E)\n",pwf->nord,data);
  if (pwf->nord == 0) return -1;
  pwf->udf = 0;
  return 0;
I can definitely see now the the advantages of using stream device. I my system control needs become more complicated I'll switch over to using that instead of asynGpib.
Cheers,
Andrew
On Mon, 30 Jul 2012, Eric Norum wrote:
I put together a simple StreamDevice/ASYN application and a small python script to provide a dummy 'instrument'.   The instrument provides 30000 values on demand.
Things seem to work as expected.  Here's the output from the final command of the startup script:
dbpr "wchk:1:Wave"
ASG:                BUSY: 0             DESC: Read a long waveform
DISA: 0             DISP: 0             DISV: 1             NAME: wchk:1:Wave
NORD: 30000         SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL: 0x0
As you can see, the IOC has successfully read 30000 double values from the instrument.
Andrew -- perhaps you can massage the attached application a little to match the commands of your hardware and see if things work for you as well?
Re: Waveform read problems Eric Norum
Prev: Re: Waveform read problems Eric Norum
Next: Re: Waveform read problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
