Subject: Re: Problem with the basic example
To: <[email protected]>
Date: Tue, 31 Jul 2012 16:19:54 +0200
On Tuesday, July 31, 2012, Bruno Seiva Martins wrote:
> I don't know if this is the place for a begginer question, but here I go.
It is, and you are welcome.
> I'm starting out using EPICS, following basic tutorials. I was able to
> compile epics base without a problem. Then I created the example IOC
> using makeBaseApp.pl.
> Everything went fine, and I got the IOC to run:
> epics> dbl
> bruno.martinsHost:aiExample
> bruno.martinsHost:aiExample1
> bruno.martinsHost:aiExample2
> bruno.martinsHost:aiExample3
> bruno.martinsHost:aSubExample
> bruno.martinsHost:calc1
> bruno.martinsHost:calc2
> bruno.martinsHost:calc3
> bruno.martinsHost:calcExample
> bruno.martinsHost:calcExample1
> bruno.martinsHost:calcExample2
> bruno.martinsHost:calcExample3
> bruno.martinsHost:compressExample
> bruno.martinsHost:subExample
> bruno.martinsHost:xxxExample
> But then, when I tried to get more details about one of these PV's, I
> got:
> epics> dbpr bruno.martinsHost:aiExample3
> Record 'bruno.martinsHost:aiExample3' not found
> I got this message for every PV I tried, and I don't really know what
> went wrong, since the PV's are being listed...
As otehr have noted, dot ('.') is not allowed in record names.
However, your db file should have been rejected when loading, and not when
trying to find the record. So this is actually a bug in EPICS base.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problem with the basic example Benjamin Franksen
Re: Problem with the basic example Bruno Seiva Martins
Prev: Re: Problem with the basic example Ned Arnold
Next: Re: Problem with the basic example Ralph Lange
Prev: Re: Problem with the basic example Benjamin Franksen
Next: Re: Problem with the basic example Benjamin Franksen
