Subject: Re: Problem with the basic example
To: <[email protected]>
Date: Tue, 31 Jul 2012 16:30:50 +0200
On Tuesday, July 31, 2012, Benjamin Franksen wrote:
> As otehr have noted, dot ('.') is not allowed in record names.
> However, your db file should have been rejected when loading, and not
> when trying to find the record. So this is actually a bug in EPICS base.
OMG, forget I wrote this. Let me try once again:
As others have noted, dot ('.') is not allowed in record names.
However, your db file should have been rejected by dbLoadRecords. Instead,
it accepted your records with the bad names, and even dbl listed them,
presumably because dbl directly processes the stored list of records, in
contrast to dbpr which needs to lookup the record by name: it is this name
lookup which assumes the first dot separates record name from field name.
So you happened to find a bug in EPICS base on your first try.
Congratulations!  ;-))
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problem with the basic example Bruno Seiva Martins
Re: Problem with the basic example Benjamin Franksen
Prev: Re: stream device string/hex parsing Dirk Zimoch
Next: Re: Problem with the basic example Bruno Seiva Martins
Prev: Re: Problem with the basic example Benjamin Franksen
