Subject: Re: Problem with the basic example
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 31 Jul 2012 11:32:18 -0300
Well, I'm glad to help (even accidentally =))!
On Tue, Jul 31, 2012 at 11:30 AM, Benjamin Franksen <[email protected]> wrote:
On Tuesday, July 31, 2012, Benjamin Franksen wrote:
> As otehr have noted, dot ('.') is not allowed in record names.
> However, your db file should have been rejected when loading, and not
> when trying to find the record. So this is actually a bug in EPICS base.
OMG, forget I wrote this. Let me try once again:
As others have noted, dot ('.') is not allowed in record names.
However, your db file should have been rejected by dbLoadRecords. Instead,
it accepted your records with the bad names, and even dbl listed them,
presumably because dbl directly processes the stored list of records, in
contrast to dbpr which needs to lookup the record by name: it is this name
lookup which assumes the first dot separates record name from field name.
So you happened to find a bug in EPICS base on your first try.
Congratulations!  ;-))
Cheers
Ben
Bruno Seiva Martins
Departamento de Computação
Universidade Federal de São Carlos - UFSCar
Problem with the basic example Bruno Seiva Martins
Re: Problem with the basic example Benjamin Franksen
Prev: Re: Problem with the basic example Bruno Seiva Martins
Next: Re: Problem with the basic example Michael Johnson
Prev: Re: Problem with the basic example Benjamin Franksen
Next: Re: Problem with the basic example Bruno Seiva Martins
