Subject: Re: aSub INPA field and CPP attribute on win32-x86 platform
To: [email protected]
Date: Thu, 2 Aug 2012 15:19:25 -0500
Hi Janez,
On 2012-08-02 Janez Golob wrote:
> I am using the following configuration:
>   - EPICS base: 3.14.12 (win32-x86 and win32-x86-debug targets)
>   - Compiler: Visual C++ 2010 Express
I can't replicate your problem here using 3.14.12.2 and Visual Studio 2008.
There were no changes to the aSub record type code between 3.14.12 and
3.14.12.2 so that's not the problem.
What kind of machine are you running this on, how many CPUs?  Not that I can
see how that would obviously cause this, but it might cause funny things if
the dbCa link connected sooner than we were expecting.
Can you send us a stack-trace from the getCharChar() routine when it's
crashing, that would help quite a lot.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: aSub INPA field and CPP attribute on win32-x86 platform Janez Golob
Prev: Re: Cross-compilation, static build, etc Andrew Johnson
Next: StreamDevice for Varian TPS-Compact Turbo Pump ? John Dobbins
Prev: aSub INPA field and CPP attribute on win32-x86 platform Janez Golob
Next: Re: aSub INPA field and CPP attribute on win32-x86 platform Janez Golob
