Subject: Re: Cross-compilation, static build, etc
To: [email protected]
Date: Thu, 2 Aug 2012 13:21:30 -0500
Hi Bruno,
On 2012-08-02 Bruno Seiva Martins wrote:
> Looking closely, indeed using 'STATIC_BUILD=YES' compiled EPICS code
> statically to my executable, leaving only the shared system libraries out.
> I guess I will build a virtual machine with my target's Linux distribution
> and compile from it, although a cross compiler would be neater =)
Google does find some ways to get around this (including a Stack Overflow
question that goes into details about defining appropriately-versioned
symbols) so in theory it should be possible to do, but I suspect a VM will be
much easier in the end.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Cross-compilation, static build, etc Bruno Seiva Martins
RE: Cross-compilation, static build, etc Mark Rivers
Prev: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Next: Re: aSub INPA field and CPP attribute on win32-x86 platform Andrew Johnson
Next: Re: Cross-compilation, static build, etc Bruno Seiva Martins
