Subject: Re: Cross-compilation, static build, etc
Cc: [email protected]
Date: Thu, 2 Aug 2012 20:57:25 -0300
Hi Andrew,
I came across that StackOverflow question too and tried the steps showed in the answer, but unluckly the offending symbol didn't have a correspondent in an older version... I'll try the VM approach, and in the meantime will think of other possible solutions. If I find one, I'll post it here.
Bruno Seiva Martins
On Thu, Aug 2, 2012 at 3:21 PM, Andrew Johnson <[email protected]> wrote:
Hi Bruno,
On 2012-08-02 Bruno Seiva Martins wrote:
> Looking closely, indeed using 'STATIC_BUILD=YES' compiled EPICS code
> statically to my executable, leaving only the shared system libraries out.
> I guess I will build a virtual machine with my target's Linux distribution
> and compile from it, although a cross compiler would be neater =)
Google does find some ways to get around this (including a Stack Overflow
question that goes into details about defining appropriately-versioned
symbols) so in theory it should be possible to do, but I suspect a VM will be
much easier in the end.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Cross-compilation, static build, etc Bruno Seiva Martins
RE: Cross-compilation, static build, etc Mark Rivers
Re: Cross-compilation, static build, etc Andrew Johnson
Prev: StreamDevice for Varian TPS-Compact Turbo Pump ? John Dobbins
Next: RE: StreamDevice for Varian TPS-Compact Turbo Pump ? Boyes, Matthew
Prev: Re: Cross-compilation, static build, etc Andrew Johnson
Next: Re: Cross-compilation, static build, etc Bruno Seiva Martins
