Subject: Re: Cross-compilation, static build, etc
Cc: [email protected]
Date: Tue, 7 Aug 2012 14:17:35 -0300
Just to let you all know, the idea of compiling from inside a VM was bugging me a lot, so I went to the trouble of building a toolchain to be able to cross compile my IOC to my target system.
It was painful and bloody, but I succeeded.
The general steps I took:
Download and configure crosstool-NG with the version numbers of my target's kernel, binutils, glibc and gcc
Generate the toolchain
Compile both 'readline' and 'ncurses' using that brand new toolchain
Configure EPICS to use my toolchain and compile it
Compile the IOC and copy it to my target
If there's enough interest in this process, I can write a detailed guide of what I did.
Bruno Seiva Martins
On Thu, Aug 2, 2012 at 8:57 PM, Bruno Seiva Martins <[email protected]> wrote:
Hi Andrew,
I came across that StackOverflow question too and tried the steps showed in the answer, but unluckly the offending symbol didn't have a correspondent in an older version... I'll try the VM approach, and in the meantime will think of other possible solutions. If I find one, I'll post it here.
Bruno Seiva Martins
On Thu, Aug 2, 2012 at 3:21 PM, Andrew Johnson <[email protected]> wrote:
Hi Bruno,
On 2012-08-02 Bruno Seiva Martins wrote:
> Looking closely, indeed using 'STATIC_BUILD=YES' compiled EPICS code
> statically to my executable, leaving only the shared system libraries out.
> I guess I will build a virtual machine with my target's Linux distribution
> and compile from it, although a cross compiler would be neater =)
Google does find some ways to get around this (including a Stack Overflow
question that goes into details about defining appropriately-versioned
symbols) so in theory it should be possible to do, but I suspect a VM will be
much easier in the end.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Cross-compilation, static build, etc Jack
Cross-compilation, static build, etc Bruno Seiva Martins
RE: Cross-compilation, static build, etc Mark Rivers
Re: Cross-compilation, static build, etc Bruno Seiva Martins
Re: Cross-compilation, static build, etc Andrew Johnson
Prev: Searching Postdoc appointment in particle physics Florian Feldbauer
Next: Re: EPICS build on armv6l Metin Aydar
Prev: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Next: Re: Cross-compilation, static build, etc Jack
