Subject: Re: EPICS build on armv6l
To: [email protected]
Cc: [email protected]
Date: Wed, 8 Aug 2012 03:12:30 +0300
As you can find on the link: http://www.aps.anl.gov/epics/base/R3-15, EPICS base is ready to test on RPi. Because it has support for ARM host based setup!
I've downloaded the base and give a chance to run on RPi, every command i wrote was successfully run... EpicsHostArch script in startup directory gives "linux-arm" as host arch. It was hard to port other architecture files to linux-arm. It took about an hour to set up new base.
After setting up new base, i run selftest command: "make runtest". All tests passed successfully.
In addition to base module, probe, medm and visualdct extensions can be set up. They all are working properly. I just used lesstif2-dev package instead of libmotif-dev.
Metin.
Ankara University
Institute of Accelerator Technologies
Control Systems Division
Hi Florian & Tim,
On 2012-06-13 Florian Feldbauer wrote:
> worked for me too. Tim is right, you have to include
> $(CONFIG)/CONFIG.gnuCommon, too, in order
> to have the $(CC) and $(CCC) macros in the Makefiles
> defined.
Great.  The gnuCommon include should go in CONFIG.linux-arm.linux-arm to match
what happens with the linux-x86 target.  The CONFIG.linux-x86.linux-x86 file
also has a few settings associated with building static binaries and shared
libraries which might be needed on arm; I don't see anything in them that is
x86-specific, but I'm not sure it they're required or not.
Once we've worked out exactly what they should be I'll add these files to the
3.14 branch so they appear in the 3.14.12.3 release.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: EPICS build on armv6l Metin Aydar
Prev: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Next: Re: Cross-compilation, static build, etc Jack
Prev: RE: EPICS build on armv6l Tim Robinson
Next: Re: EPICS build on armv6l Metin Aydar
