Subject: Re: EPICS build on armv6l
Date: Thu, 9 Aug 2012 08:41:19 +0300
Hi all,
As you can find on the link: http://www.aps.anl.gov/epics/base/R3-15, EPICS base is ready to test on RPi hosts. Now, it supports ARM host based setup! It was hard to port other architecture files to linux-arm in previous version.
I've downloaded the base and gave a chance to run on RPi, every command i wrote was successfully run...
EpicsHostArch script in startup directory gives "linux-arm" as host arch. It took about an hour to set up new base.
After setting up new base, i run selftest command: "make runtest". All tests passed successfully.
In addition to base module; probe and medm extensions can be set up. They all are working properly. I just used lesstif2-dev package instead of libmotif-dev. And i could setup java runtime version 6-dev to run visualdct..
Metin.
Ankara University
Institute of Accelerator Technologies
Control Systems Division
Re: EPICS build on armv6l Metin Aydar
Prev: RE: Remaining free buffers in an AD plugin queue Mark Rivers
Next: Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Prev: Re: EPICS build on armv6l Metin Aydar
Next: thermocouple solutions Wesley Moore
