Subject: Re: EPICS Base version 3.15.0.1 released
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Aug 2012 15:18:50 +0200
Dirk Zimoch wrote:
When building modules (here asyn4-19) against an EPICS base in an INSTALL_LOCATION, the header files in $(EPICS_BASE)/include/os/$(OS_CLASS) are not found. With an EPICS base without INSTALL_LOCATION it works.
Dirk
Linux builds work (including cross embedded linux builds). I see the problem only for vxWorks builds.
False alarm. Accidentally I did not install EPICS base globally for vxWorks. Then the include/os/vxWorks directory does not exist. And the include path generation does not add non-existing paths.
Dirk
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Prev: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Next: EPICS 3.15 generates strange shared library names Dirk Zimoch
Next: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
