1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Creating INLINK/OUTLINK in record support
To: [email protected]
Cc: "Zhang, Dehong" <[email protected]>
Date: Thu, 23 Aug 2012 17:06:55 -0500
Hi Dehong,
On 2012-08-23 Zhang, Dehong wrote:
> Is it possible to create these things dynamically inside a record, so that
> I can access PVs on another IOC, without listing them all in the dbd file
> of my custom record?
> In other words, is there something like the
> dbNameToAddr
> to use for creating and accessing LINKs?
Anything is possible if you're willing to write enough code, but...
The dbNameToAddr() routine is only for local PVs; CA links are implemented
using the code in dbCa, and initializing those links happens at iocInit() or
whenever the INP/OUT link value is changed.  However there isn't really a
public API for that kind of thing, and I don't really recommend that you try
to do that.
It sounds to me like you're creating a new record type when maybe you should
be writing a State Notation Language program.  Why don't you step back a bit
and reconsider what you're trying to do?  Feel free to explain here if you
want more advice, but you will need to explain the bigger picture because I
wouldn't recommend trying what you describe above.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: Creating INLINK/OUTLINK in record support Zhang, Dehong
Prev: Re: Motor Record 6-5-2 backlash issue? Kurt Goetze
Next: Re: Creating INLINK/OUTLINK in record support Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Creating INLINK/OUTLINK in record support Zhang, Dehong
Next: RE: Creating INLINK/OUTLINK in record support Zhang, Dehong
