Subject: Re: Creating INLINK/OUTLINK in record support
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Thu, 23 Aug 2012 17:21:48 -0500 (CDT)
Hi Dehong,
Well, there is recDynLink, which provided retargetable links for the scan record, back in the days before all EPICS links became retargetable.  I think I would be wary of using recDynLink in new code, because it uses unpublished resources from base.
What's the problem you're trying to avoid with having link fields in the .dbd file?
Is it that you don't know in advance how many links you'll need?
Tim
----- Original Message -----
To: [email protected]
Sent: Thursday, August 23, 2012 3:19:49 PM
Subject: Creating INLINK/OUTLINK in record support
Is it possible to create these things dynamically inside a record, so that
I can access PVs on another IOC, without listing them all in the dbd file of
my custom record?
In other words, is there something like the
dbNameToAddr
to use for creating and accessing LINKs?
Thanks and best regards,
Dehong
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Creating INLINK/OUTLINK in record support Zhang, Dehong
Prev: Re: Creating INLINK/OUTLINK in record support Andrew Johnson
Next: Re: Motor Record 6-5-2 backlash issue? Tim Mooney
Prev: Re: Mass PV assign and event flag sync [was: Creating INLINK/OUTLINK in record support] Andrew Johnson
Next: Problem with medmfonts.ali running under Ubuntu 1204 Ivan
