Subject: Re: EDM X Error on Linux
To: Jason Abernathy <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2012 09:32:31 -0300
Hello everyone again,
By following the suggestion from Jason Abernathy:
From Jason Abernathy:
I have found that running EDM will yield the error
Error: No realize class procedure defined
after an (apparantly) successful build on an Ubuntu 11.10 system.
This can be solved modifying the edmMain/Makefile
    edm_LIBS_Linux += Xm Xmu Xt Xp Xtst X11
    USR_LDFLAGS_Linux += -Wl,--no-as-needed<--- add this line
    edm_SYS_LIBS_Linux += pthread dl
I managed to get EDM working (or so it seems).
I noticed that the EDM compiled with the makefile modification has six more dynamic links, namely:
> ldd $EDM
libXtst.so.6 => /usr/lib/x86_64-linux-gnu/libXtst.so.6 (0x00007f174e552000)
libca.so.3.14 => /opt/epics/base/lib/linux-x86_64/libca.so.3.14 (0x00007f174dfb8000)
libCom.so.3.14 => /opt/epics/base/lib/linux-x86_64/libCom.so.3.14 (0x00007f174dd5f000)
libreadline.so.6 => /lib/x86_64-linux-gnu/libreadline.so.6 (0x00007f174d6fb000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f174d4f2000)
libtinfo.so.5 => /lib/x86_64-linux-gnu/libtinfo.so.5 (0x00007f174ba91000)
If I may ask, how did you realize that the option --no-as-needed could solve the problem?
Perhaps it was noted that some important libraries weren't linked against? If so, why didn't
they get referenced in order to be included by the linker?
Thank you all once again!
Best Regards,
Lucas
On Sat, Aug 25, 2012 at 3:59 PM, Lucas Russo <[email protected]> wrote:
Hello Jason and John,
Thank you very much for the responses.
I'm going to try to rebuild the EDM by modifying the Makefile as suggested first.
If, however, I'm unsuccessful the PPA from Jason seems a good source of epics related
packages.
Thanks again!
Lucas
On Sat, Aug 25, 2012 at 3:06 PM, Jason Abernathy <[email protected]> wrote:
Hello Lucas,
You can also installed EDM on Ubuntu via my Debian personal package archive for EPICS:
https://launchpad.net/~j-abernathy/+archive/epics-ppa
p.s. does anyone know how to respond to a single message from the daily Tech-talk summary?
Re: EDM X Error on Linux Jason Abernathy
Re: EDM X Error on Linux Lucas Russo
Prev: Re: EDM X Error on Linux Lucas Russo
Next: Re: Creating INLINK/OUTLINK in record support Tim Mooney
Next: Fwd: EDM X Error on Linux Lucas Russo
