1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: aiRecord conversion
To: [email protected]
Date: Tue, 28 Aug 2012 09:48:05 -0300
Hi all,
I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter.
My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0
For 10 volts, 4095
I configured the conversion fields as follows:
EGUF: 10
EGUL: -10
AOFF: 0
ASLO: 1
EOFF: 0
ESLO 0.004884   // which is (EGUF - EGUL) / 4095
ROFF: 0
LINR: LINEAR
Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
The record processing routine performs the following algorithm for all records except those that use the Soft Channel device support routine. Be aware that step 3 is performed only when the record specifies LINEAR:
1. Val= RVAL + ROFF
2. Val = Val * ASLO + AOFF
If the conversion algorithm is LINEAR, the raw value is converted via the equation:
3. val = val * ESLO + EGUL
Seems like the step 3 is not being completely executed, or considering EGUL = 0...
Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance,
Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
Re: aiRecord conversion Eric Norum
Prev: Re: Creating INLINK/OUTLINK in record support Tim Mooney
Next: Re: aiRecord conversion Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fwd: EDM X Error on Linux Lucas Russo
