Subject: Re: aiRecord conversion
To: Bruno Seiva Martins <[email protected]>
Cc: [email protected]
Date: Tue, 28 Aug 2012 06:45:05 -0700
Perhaps you misread the wiki page.  EGUL does not take part in the conversions.
Here is the salient portion of the wiki page:
The record processing routine performs the following algorithm for all records except those that use the Soft Channel device support routine. Be aware that step 3 is performed only when the record specifies LINEAR:
1. Val= RVAL + ROFF
2. Val = Val * ASLO + AOFF
If the conversion algorithm is LINEAR, the raw value is converted via the equation:
3. val = val * ESLO + EOFF
If the conversion is via a breakpoint table, the new value is obtained.
On Aug 28, 2012, at 5:48 AM, Bruno Seiva Martins <[email protected]> wrote:
Hi all,
I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter.
My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0
For 10 volts, 4095
I configured the conversion fields as follows:
EGUF: 10
EGUL: -10
AOFF: 0
ASLO: 1
EOFF: 0
ESLO 0.004884   // which is (EGUF - EGUL) / 4095
ROFF: 0
LINR: LINEAR
Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
1. Val= RVAL + ROFF
3. val = val * ESLO + EGUL
Seems like the step 3 is not being completely executed, or considering EGUL = 0...
Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance,
Bruno Seiva Martins
Eric Norum
[email protected]
Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Nicholas P. DiMonte
Prev: Re: aiRecord conversion Bruno Seiva Martins
Next: Re: aiRecord conversion Ralph Lange
Prev: Re: aiRecord conversion Eric Norum
Next: Re: aiRecord conversion Bruno Seiva Martins
