Subject: Re: aiRecord conversion
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 28 Aug 2012 10:28:34 -0300
Rectifying:
   epicsFloat64 div;
   pao->eguf = 10.0;
   pao->egul = (type == LCN12BMP || type == LCN16BMP) ? 0.0 : -10.0;
   div = (type == LCN12BMP || type == LCN12BBP) ? 4095.0 : 65535.0;
   pao->hopr = pao->eguf;
   pao->lopr = pao->egul;
   pao->eslo = ((pao->eguf) - (pao->egul)) / div;
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 10:26 AM, Bruno Seiva Martins <[email protected]> wrote:
Hi Dirk,
I wrote a custom Device Support for this record, so DTYP is set to my custom device. Indeed, it is the device support code that sets those parameters, but only in the init_record routine:
   epicsFloat64 div;
   pao->eguf = 10.0;
   pao->hopr = *eguf;
   pao->lopr = *egul;
After the initialization, those parameters are not changed. The read_ai routine only reads into the RVAL field.
   struct loconState *priv = pao->dpvt;
   epicsUInt16 value = 0;
   LOCON_read_analog(priv->address, priv->type, &value);
   pao->rval = (epicsInt32) value;
   return 0;
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 10:12 AM, Dirk Zimoch <[email protected]> wrote:
Hi Bruno,
Many drivers overwrite EOFF and ESLO with their own calculations (from EGUL and EGUF and their own assumptions about the raw value range).
So the important missing information is: What driver are you using (DTYP)?
Dirk
Bruno Seiva Martins wrote:
Hi all,
I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter.
My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0
For 10 volts, 4095
I configured the conversion fields as follows:
EGUF: 10
EGUL: -10
AOFF: 0
ASLO: 1
EOFF: 0
ESLO 0.004884   // which is (EGUF - EGUL) / 4095
ROFF: 0
LINR: LINEAR
Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
    The record processing routine performs the following algorithm for
    all records except those that use the |Soft Channel| device support
    routine. Be aware that step 3 is performed only when the record
    specifies LINEAR:
    1. Val= RVAL + ROFF
    2. Val = Val * ASLO + AOFF
    If the conversion algorithm is |LINEAR|, the raw value is converted
    via the equation:
    3. val = val * ESLO + EGUL
Seems like the step 3 is not being completely executed, or considering EGUL = 0...
Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance,
Bruno Seiva Martins
Re: aiRecord conversion Ralph Lange
aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
Re: aiRecord conversion Bruno Seiva Martins
Prev: Re: aiRecord conversion Bruno Seiva Martins
Next: Re: aiRecord conversion Eric Norum
Next: Re: aiRecord conversion Ralph Lange
