I think it's good for EPICS to cede responsibility for the posting of VAL fields to record-support code (when that code will run) because this permits the record more effectively to reject an unsuitable new value. If a client has a monitor on the VAL field, the client will never see the rejected value, so it won't trigger unwanted processing, etc.
I do agree that EPICS could do a more thorough job of determining when the record will process. DISA is a problem because it won't be updated until the record actually is processed, which won't happen until after dbPut() returns. But I'm not sure I really would want EPICS to post changes to VAL when disa==disv, and again the worrisome scenario is a client ready to process when it receives a monitor. While the record is active, the client is shielded from certain values, but while the record is disabled, the client responds to whatever anybody writes. I can imagine a use case for that behavior, but I think more often I'd want a VAL-driven client to be disabled while the record is disabled.
Tim
----- Original Message -----
To: "EPICS" <[email protected]>
Sent: Thursday, August 30, 2012 4:36:23 AM
Subject: put to disabled records and monitors
Hi folks,
A colleague of mine has seen the following strange effect:
If a disabled (DISA=1) record is written then monitors do not show the
change. To be exact: If the VAL field of a passive record is modified
multiple times, then a monitor shows only the first change. But if the
record is scanned periodically, or any other field with pp(TRUE) has
been written before, then even the first change is not shown. However, a
caget can confirm that the value has changed.
Even when the record is re-enabled (DISA=0), the monitors do not update
before the record processes the next time.
Other fields than the VAL field are not affected, all of their
modifications are immediately shown by monitors.
So it seems if any attempt has been made to process a disabled record,
then any later modification of the VAL field and only the VAL field does
not trigger a monitor.
Is this the correct behavior? IMHO no. It leads to inconsistent displays
for the same value. As for any other field, people also want to see any
change that someone else makes on the VAL field.
The problem appeared when a epid record had to be configured (KP, KI,
and KD set, as well as the setpoint VAL), before is is activated. Other
displays did not show the modified setpoint. I could confirm that the
problem is not limited to the epid record but affects standard base
record like ao as well.
The code in question seems to be dbPut in dbAccess.c:
/* Propagate monitor events for this field, */
/* unless the field field is VAL and PP is true. */
pfldDes = paddr->pfldDes;
isValueField = dbIsValueField(pfldDes);
if (isValueField) precord->udf = FALSE;
if (precord->mlis.count &&
!(isValueField && pfldDes->process_passive))
db_post_events(precord, paddr->pfield, DBE_VALUE | DBE_LOG);
What about changing this to
!(isValueField && pfldDes->process_passive &&
precord->disa != precrod->disv))
or skip the whole test for VAL and do
if (precord->mlis.count)
Any opinions?
Dirk
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- Re: put to disabled records and monitors Tim Mooney
- put to disabled records and monitors Dirk Zimoch
Re: Keithley 6517B support? Joe Sullivan
<2012>
2025
2026
<2012>
2025
2026
