Subject: Re: edm and other extensions on 64-bit SL machines
To: [email protected]
Date: Fri, 31 Aug 2012 17:45:32 -0500
Hi Pierrick,
On 2012-08-31 Pierrick Hanlet wrote:
> Both edm and alh require libXm (and perhaps others of that suite).  Each
> fail to build with
> the error:
>   No rule to make target `/usr/lib/libXm.a'.
> This tells me that it searched and expects to find the library in
> /usr/lib.  If I understand things
> correctly, should it not be searching in /usr/lib64 since that is where
> the libraries reside?
Take a look at the file
  extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
which should set those paths for you.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Re: edm and other extensions on 64-bit SL machines Jennings Guy
Prev: RE: edm and other extensions on 64-bit SL machines Mark Rivers
Next: Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Prev: Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
