Subject: Re: edm and other extensions on 64-bit SL machines
Cc: Tech Talk <[email protected]>
Date: Fri, 31 Aug 2012 17:47:03 -0500
Hi Mark,
There are both libraries.
Pierrick
On 08/31/2012 05:44 PM, Mark Rivers wrote:
And is there a libXm.a, or only libXm.so?
Sent: Friday, August 31, 2012 5:27 PM
To: Jennings Guy
Cc: Mark Rivers; Tech Talk
Hi all,
I do have EPICS_HOST_ARCH set to linux-x86_64.  I'm confident that this is correct since
the O.linux-x86_64 directories are created.  I also do have openMotif-devel.  I attempted
to yum install the non-64 bit versions of the libraries, but yum didn't allow me to do so.
My base appears to have built correctly, as I noticed that it pointed to 64 bit libraries.
Both edm and alh require libXm (and perhaps others of that suite).  Each fail to build with
the error:
 No rule to make target `/usr/lib/libXm.a'.
This tells me that it searched and expects to find the library in /usr/lib.  If I understand things
correctly, should it not be searching in /usr/lib64 since that is where the libraries reside?
Pierrick
On 08/31/2012 04:30 PM, Jennings Guy wrote:
On Aug 31, 2012, at 4:18 PM, Mark Rivers wrote:
You need to set EPICS_HOST_ARCH to linux-x86_64 so that you are building a 64-bit application, not a 32-bit application.
You also need to make sure you have installed the openMotif package, which many newer Linux distributions do not include by default.
You'll need the openmotif-devel package as well
From: [email protected] [mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Friday, August 31, 2012 4:06 PM
To: Tech Talk
Subject: edm and other extensions on 64-bit SL machines
I'm using 3.14.12 on a 64-bit Scientific Linux machine.  I'm attempting to build extensions
such as edm, but always fail when the linker asks for libraries such as libXm, etc.  The
message states that it is searching for the libraries in /usr/lib, but as a 64-bit machine,
these libraries are in /usr/lib64.  I've searched tech-talk archives, but have been unsuccessful
in finding what switch (flag) I need to set to force it to link to the correct libraries.  Would
someone kindly point me in the right direction?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Pierrick Hanlet
IIT/Fermilab
Pierrick Hanlet
IIT/Fermilab
edm and other extensions on 64-bit SL machines Pierrick Hanlet
RE: edm and other extensions on 64-bit SL machines Mark Rivers
Re: edm and other extensions on 64-bit SL machines Jennings Guy
Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Prev: Re: edm and other extensions on 64-bit SL machines Andrew Johnson
Next: Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Prev: RE: edm and other extensions on 64-bit SL machines Mark Rivers
Next: Re: edm and other extensions on 64-bit SL machines Andrew Johnson
