Subject: Re: EPICS build system, RELEASE file, and relative paths
To: [email protected]
Date: Fri, 7 Sep 2012 10:47:48 -0500
Hi Angus,
On 2012-09-07 Angus Gratton wrote:
> I'm curious about how people manage paths in RELEASE, like EPICS_BASE,
> ASYN, etc.
> So it all made me wonder - how does everyone else do it?
As a contrast to Mark Rivers post about how synApps manages versions which is
good for experimental installations, the approach we use for the Accelerator
systems here at APS is better suited to an installation with the more formal
approach to change control that is called for to provide highly reliable 24×7
machine operation.
We use absolute paths, with intermediate variables to remove duplication,
something like this:
SUPPORT = /home/epics/3.14.12.2
ASYN = $(SUPPORT)/modules/soft/asyn/4-19-aps2
EPICS_BASE = $(SUPPORT)/base/3-14-12-2-aps1
This is for installation of modules and IOCs in the shared (NFS-mounted)
production area which is under change control.  Note that the full path to
Asyn is /home/epics/3.14.12.2/modules/soft/asyn/4-19-aps2 so all modules
including Base itself are built in an area that is specific to the version of
Base (3.14.12.2), and we have a local -aps<n> version number on the end so we
can have multiple local versions of the same module release installed.
We have a rule that we *never* modify or rebuild a module installed in the
production area once a production IOC has been built using that version.  If
we need to fix problems with the code we build a new local version containing
that bug fix which has an incremented -aps version number.
We also increment the -aps<n> version number when we install a new version of
say Asyn that have other modules downstream that rely on it, say modbus.  We
might have modules/plc/modbus/2-3-aps1 built using modules/soft/asyn/4-18-aps1
and modules/plc/modbus/2-3-aps2 built using modules/soft/asyn/4-19-aps1; the
only difference between the source code of those two modbus versions is the
ASYN line in their configure/RELEASE files.  This way we can never break any
production IOCs when we install new versions of support modules, because the
person responsible for editing an IOC's RELEASE file is the engineer in charge
of the IOC area and if she doesn't change it the IOC will continue to use the
old version.
A developer who is updating an IOC or working on a new version of a support
module will want to use as many of the production-built modules as possible
during development, but if there's a new version say of Asyn that he needs he
may have a local copy of that built under his home directory, and will change
the ASYN pointer in his IOC to use that version instead while he's working on
it:
#ASYN = $(SUPPORT)/modules/soft/asyn/4-20-aps1
ASYN = /home/anj/modules/soft/asyn/4-20
He shouldn't commit that RELEASE file change to CVS though because production
builds should never refer to non-production modules, so he'll request that
Asyn version 4-20 be built (as version 4-20-aps1) in the production 3.14.12.2
area and point his RELEASE file to that before he can commit and have his IOC
built in production.
HTH.
As to your patch, it looks reasonable, but I wonder what abs_path() is doing
that rel2abs() isn't?  Is it working around an automounter issue, or are you
using soft links?
> Index: base/src/tools/EPICS/Path.pm
> --- base/src/tools/EPICS/Path.pm        (revision 1268)
> +++ base/src/tools/EPICS/Path.pm        (revision 1269)
> @@ -123,6 +123,9 @@
>      # Now calculate the absolute path
>      my $abs = File::Spec->rel2abs($path, abs_path($cwd));
> +    if (-e $abs) {
> +        $abs = abs_path($abs);
>      return LocalPath($abs);
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: EPICS build system, RELEASE file, and relative paths Angus Gratton
Prev: sequencer release 2.1.10 Benjamin Franksen
Next: Re: Epics driver using BLT or CBLT to read FIFO wanted Michael Davidsaver
Prev: RE: EPICS build system, RELEASE file, and relative paths Mark Rivers
Next: Re: EPICS build system, RELEASE file, and relative paths Angus Gratton
