Subject: RE: windows-x64 tool versions
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 10 Sep 2012 17:59:34 +0000
The mingw32 version of make often has problems, but I've never had problems with the GnuWin32 version:
J:\epics\devel\quadEM>"c:\Program Files (x86)\GnuWin32\bin\make.exe" -v
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i386-pc-mingw32
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Monday, September 10, 2012 10:36 AM
To: [email protected]
Subject: windows-x64 tool versions
Hi
Are there particular tool versions I need to build base-3.14.12.2 with out of the box configuration on windows-x64? I get this link error using these tools:
Visual Studio 2010:
Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
U:\epics\base-3.14.12.2>perl -v
This is perl 5, version 12, subversion 4 (v5.12.4) built for MSWin32-x64-multi-t
hread
U:\epics\base-3.14.12.2>c:\MinGW\bin\mingw32-make.exe -v
GNU Make 3.82
Built for i386-pc-mingw32
make
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release /ve
rsion:3.14  /MACHINE:X64    /implib:com.lib /out:com.dll        bucketLib.obj ep
icsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj cvtFast.obj re
sourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj envSubr.
obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj fdManager.obj f
reeListLib.obj gpHashLib.obj iocsh.obj registry.obj libComRegister.obj iocLog.ob
j logClient.obj macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj adjustment.obj
cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj epicsString.obj t
runcateFile.obj ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj epicsThread.obj
epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj epicsMath.obj
epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.o
bj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAssert.obj osdFi
ndSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv.obj epicsRe
adline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.obj osdMutex.
obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj osdMessageQueue.obj d
evLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj timerQueue.obj
 timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj tsDefs.obj e
picsGetopt.obj setThreadName.obj forceBadAllocException.obj
   Creating library com.lib and object com.exp
fdManager.obj : error LNK2001: unresolved external symbol __WSAFDIsSet
fdManager.obj : error LNK2001: unresolved external symbol __imp_WSAGetLastError
fdManager.obj : error LNK2001: unresolved external symbol __imp_select
logClient.obj : error LNK2001: unresolved external symbol __imp_send
logClient.obj : error LNK2001: unresolved external symbol __imp_setsockopt
logClient.obj : error LNK2001: unresolved external symbol __imp_shutdown
logClient.obj : error LNK2001: unresolved external symbol __imp_htons
logClient.obj : error LNK2001: unresolved external symbol __imp_connect
aToIPAddr.obj : error LNK2001: unresolved external symbol __imp_htonl
osdSock.obj : error LNK2001: unresolved external symbol __imp_accept
osdSock.obj : error LNK2001: unresolved external symbol __imp_gethostbyname
osdSock.obj : error LNK2001: unresolved external symbol __imp_gethostbyaddr
osdSock.obj : error LNK2001: unresolved external symbol __imp_closesocket
osdSock.obj : error LNK2001: unresolved external symbol __imp_socket
osdSock.obj : error LNK2001: unresolved external symbol __imp_WSACleanup
osdSock.obj : error LNK2001: unresolved external symbol __imp_WSAStartup
osiSock.obj : error LNK2001: unresolved external symbol __imp_ntohs
osiSock.obj : error LNK2001: unresolved external symbol __imp_ntohl
osdProcess.obj : error LNK2001: unresolved external symbol __imp_MessageBoxA
osdProcess.obj : error LNK2001: unresolved external symbol __imp_GetUserNameA
osdNetIntf.obj : error LNK2001: unresolved external symbol __imp_WSAIoctl
com.dll : fatal error LNK1120: 21 unresolved externals
mingw32-make[3]: *** [Com.dll] Error 1120
mingw32-make[3]: Leaving directory `U:/epics/base-3.14.12.2/src/libCom/O.windows
-x64'
mingw32-make[2]: *** [install.windows-x64] Error 2
mingw32-make[2]: Leaving directory `U:/epics/base-3.14.12.2/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory `U:/epics/base-3.14.12.2/src'
mingw32-make: *** [src.install] Error 2
RE: windows-x64 tool versions james.rowland
Prev: RE: windows-x64 tool versions Chu, Paul
Next: PIXIS-XO 100B Szalata, Zenon M.
Next: RE: windows-x64 tool versions james.rowland
