Subject: RE: windows-x64 tool versions
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 10 Sep 2012 17:12:49 +0000
What I did was to modify the startup\win32.bat and executed it before "make".  Here are the lines I modified in the file (I use Strawberry Perl and GnuWin32 make):
REM   --------------- ActiveState perl -------------------
set PATH=C:\strawberry\perl\bin;%PATH%
REM   --------------- gnuwin32 make ----------------------
set PATH=%ProgramFiles(x86)%\GnuWin32\bin;%PATH%
REM --  windows-x64 ---
call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x64
REM --  win32-x86 ---
REM call "C:\Program files (x86)\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x86
REM ======================================================
REM --------------- EPICS --------------------------------
set EPICS_HOST_ARCH=windows-x64
REM set EPICS_HOST_ARCH=win32-x86
Note: if you use Visual Studio 2010 Express (the free version), you will need to do the following extra steps:
1. Download and install Microsoft SDK 7.1
2. A patch to the SDK 7.1 (can be found here: http://www.microsoft.com/en-us/download/details.aspx?id=4422)
3. Use the following line in the win32.bat instead of the 'call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x64':
CALL "C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd" /x64
Of course, these paths are assuming your VS installed in the default place on C:\.
By the way, I did get some error with mingw32 make but no problem with GnuWin32 make.
Hope this helps.
Paul
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of [email protected]
> Sent: Monday, September 10, 2012 11:36 AM
> To: [email protected]
> Subject: windows-x64 tool versions
> Hi
> Are there particular tool versions I need to build base-3.14.12.2 with out of
> the box configuration on windows-x64? I get this link error using these tools:
> Visual Studio 2010:
> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
> U:\epics\base-3.14.12.2>perl -v
> This is perl 5, version 12, subversion 4 (v5.12.4) built for MSWin32-x64-multi-t
> hread
> U:\epics\base-3.14.12.2>c:\MinGW\bin\mingw32-make.exe -v GNU Make
> 3.82 Built for i386-pc-mingw32
> make
> link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
> /release /ve
> rsion:3.14  /MACHINE:X64    /implib:com.lib /out:com.dll        bucketLib.obj ep
> icsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj cvtFast.obj
> re sourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj
> envSubr.
> obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj
> fdManager.obj f reeListLib.obj gpHashLib.obj iocsh.obj registry.obj
> libComRegister.obj iocLog.ob j logClient.obj macCore.obj macEnv.obj
> macUtil.obj aToIPAddr.obj adjustment.obj cantProceed.obj epicsConvert.obj
> epicsExit.obj epicsStdlib.obj epicsString.obj t runcateFile.obj
> ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj epicsThread.obj
> epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj
> epicsMath.obj epicsGeneralTime.obj osiClockTime.obj osdSock.obj
> osdSockAddrReuse.obj osiSock.o bj systemCallIntMech.obj
> epicsSocketConvertErrnoToString.obj osdAssert.obj osdFi ndSymbol.obj
> osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv.obj epicsRe
> adline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.obj
> osdMutex.
> obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj
> osdMessageQueue.obj d evLibVME.obj devLibVMEOSD.obj taskwd.obj
> epicsTimer.obj timer.obj timerQueue.obj  timerQueueActive.obj
> timerQueueActiveMgr.obj timerQueuePassive.obj tsDefs.obj e
> picsGetopt.obj setThreadName.obj forceBadAllocException.obj
>    Creating library com.lib and object com.exp fdManager.obj : error LNK2001:
> unresolved external symbol __WSAFDIsSet fdManager.obj : error LNK2001:
> unresolved external symbol __imp_WSAGetLastError fdManager.obj : error
> LNK2001: unresolved external symbol __imp_select logClient.obj : error
> LNK2001: unresolved external symbol __imp_send logClient.obj : error
> LNK2001: unresolved external symbol __imp_setsockopt logClient.obj : error
> LNK2001: unresolved external symbol __imp_shutdown logClient.obj : error
> LNK2001: unresolved external symbol __imp_htons logClient.obj : error
> LNK2001: unresolved external symbol __imp_connect aToIPAddr.obj : error
> LNK2001: unresolved external symbol __imp_htonl osdSock.obj : error
> LNK2001: unresolved external symbol __imp_accept osdSock.obj : error
> LNK2001: unresolved external symbol __imp_gethostbyname osdSock.obj :
> error LNK2001: unresolved external symbol __imp_gethostbyaddr
> osdSock.obj : error LNK2001: unresolved external symbol __imp_closesocket
> osdSock.obj : error LNK2001: unresolved external symbol __imp_socket
> __imp_WSACleanup osdSock.obj : error LNK2001: unresolved external
> symbol __imp_WSAStartup osiSock.obj : error LNK2001: unresolved external
> symbol __imp_ntohs osiSock.obj : error LNK2001: unresolved external
> symbol __imp_ntohl osdProcess.obj : error LNK2001: unresolved external
> symbol __imp_MessageBoxA osdProcess.obj : error LNK2001: unresolved
> external symbol __imp_GetUserNameA osdNetIntf.obj : error LNK2001:
> unresolved external symbol __imp_WSAIoctl com.dll : fatal error LNK1120: 21
> unresolved externals
> mingw32-make[3]: *** [Com.dll] Error 1120
> mingw32-make[3]: Leaving directory `U:/epics/base-
> 3.14.12.2/src/libCom/O.windows
> -x64'
> mingw32-make[2]: *** [install.windows-x64] Error 2
> mingw32-make[2]: Leaving directory `U:/epics/base-3.14.12.2/src/libCom'
> mingw32-make[1]: *** [libCom.install] Error 2
> mingw32-make[1]: Leaving directory `U:/epics/base-3.14.12.2/src'
> mingw32-make: *** [src.install] Error 2
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If
> you are not the intended addressee or an authorised recipient of the
> addressee please notify us of receipt by returning the e-mail and do not use,
> copy, retain, distribute or disclose the information in or attached to the e-
> mail.
> Any opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
windows-x64 tool versions james.rowland
Prev: Does anyone have support for Hamamatsu ORCA Flash 4.0? nick.rees
Next: RE: windows-x64 tool versions Mark Rivers
Prev: windows-x64 tool versions james.rowland
