Subject: Re: How to profile an EPICS application on Linux
Date: Mon, 10 Sep 2012 16:48:33 -0500
On 9/10/12 4:17 PM, Mark Rivers wrote:
> Does anyone with gprof experience know why I am not getting the execution times in these functions?
Hi, Mark.
I don't have gprof experience, but it could be that your
application is spending most of its time sleeping or blocking,
so, since gprof works by taking measurements while your
application is running in user-space, it sees time spent in your
application as very small compared to time spent in
kernel-space, and thus results in times rounded to 0 for all
those function calls.
The following article talks about this toward the end:
  http://www.ibm.com/developerworks/library/l-gnuprof.html
It suggests that if you run your application with the "time"
command and the output says you're spending hardly any time in
user-space, then gprof might not be useful to you.
Lewis
RE: How to profile an EPICS application on Linux Mark Rivers
Prev: RE: camonitor bug for string as array of chars Mark Rivers
Next: Re: Doubt regarding standards followed by EPICS Andrew Johnson
Prev: How to profile an EPICS application on Linux Mark Rivers
Next: RE: How to profile an EPICS application on Linux Mark Rivers
