Subject: Re: camonitor bug for string as array of chars
Date: Mon, 10 Sep 2012 18:08:50 -0500
Hi Mark,
On 2012-09-10 Mark Rivers wrote:
> > Maybe camonitor should be \0-terminating the array that it gets from CA
> > too,
> Yes, I think it should.  It knows it's printing a string, and it knows how
>  long the array actually is, since camonitor without -S prints the correct
>  values.
If you don't include the \0 then CA clients which were expecting it will break
in the way you've found camonitor -S does.  I don't believe any CA client that
handles C strings will have any problem with a terminating \0 byte.  Bear in
mind that before R3.14.12 CA didn't support variable length arrays at all, and
every waveform array was transported at its full NELM length, with zero values
inserted following the NORD elements of data, so older clients *had* to cope
with trailing zero bytes anyway.
>  Is it documented anywhere that a
>  waveform record containing a string should include the \0, and include it
>  in the element count?
It was not officially documented anywhere that I know of that a waveform
record could be used to transport strings, until we added the long string
support to Base.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
caput off-by-one bug for string as array of chars J. Lewis Muir
Re: camonitor bug for string as array of chars Andrew Johnson
RE: camonitor bug for string as array of chars Mark Rivers
Prev: RE: How to profile an EPICS application on Linux Mark Rivers
Next: Re: How to profile an EPICS application on Linux Guy Jennings
Prev: RE: camonitor bug for string as array of chars Mark Rivers
Next: Re: camonitor bug for string as array of chars Ralph Lange
