Might be worth taking a look at the Intel Thread Profiler for Linux -
I've used the Windows version and it is excellent
at showing threading problems. It's quite expensive, but there is a
30 day evaluation version.
On Sep 10, 2012, at 6:03 PM, Mark Rivers wrote:
Thanks for the suggestion, perf record and perf report work fine.
The results are interesting. 10% of the time is spend in the
pthread_mutex code.
5.38% quadEMTestApp libpthread-2.14.1.so [.]
__pthread_mutex_unlock_usercnt
4.34% quadEMTestApp libpthread-2.14.1.so [.]
pthread_mutex_lock
a
2.36% quadEMTestApp quadEMTestApp [.]
getAddr
a
2.27% quadEMTestApp quadEMTestApp [.]
__i686
.get_pc_thunk
.bx
a
2.17% quadEMTestApp [kernel.kallsyms] [k]
_raw_spin_lock
a
1.98% quadEMTestApp quadEMTestApp [.]
paramList::int32Callback(int,
int
) a
1.95% quadEMTestApp libpthread-2.14.1.so [.]
pthread_cond_signal
@@GLIBC_2.3.2
a
1.95% quadEMTestApp [kernel.kallsyms] [k]
ia32_syscall
a
1.79% quadEMTestApp [kernel.kallsyms] [k]
__audit_syscall_exit
a
1.55% quadEMTestApp quadEMTestApp [.]
epicsMutexLock
a
1.53% quadEMTestApp [kernel.kallsyms] [k]
resched_task
a
1.47% quadEMTestApp quadEMTestApp [.]
epicsMutexOsdLock
a
1.44% quadEMTestApp [kernel.kallsyms] [k]
do_futex
a
1.41% quadEMTestApp quadEMTestApp [.]
paramList
::getParameter
(int
) a
1.35% quadEMTestApp [kernel.kallsyms] [k]
__schedule
a
1.29% quadEMTestApp quadEMTestApp [.]
getTraceMask
a
1.29% quadEMTestApp [kernel.kallsyms] [k]
update_cfs_shares
a
1.24% quadEMTestApp [kernel.kallsyms] [k]
update_curr
a
1.24% quadEMTestApp quadEMTestApp [.]
portThread
a
1.23% quadEMTestApp quadEMTestApp [.]
epicsMutexUnlock
a
1.23% quadEMTestApp [kernel.kallsyms] [k]
native_write_msr_safe
a
1.20% quadEMTestApp [kernel.kallsyms] [k]
select_task_rq_fair
a
try_to_wake_up
a
1.12% quadEMTestApp [kernel.kallsyms] [k]
update_rq_clock
a
futex_wait
a
1.09% quadEMTestApp [kernel.kallsyms] [k]
update_cfs_load
a
1.08% quadEMTestApp [kernel.kallsyms] [k]
device_not_available
a
0.92% quadEMTestApp quadEMTestApp [.]
drvQuadEM
::computePositions
(int
*) a
0.91% quadEMTestApp [kernel.kallsyms] [k]
hash_futex
a
futex_wake
a
0.89% quadEMTestApp [kernel.kallsyms] [k]
plist_add
a
0.87% quadEMTestApp [kernel.kallsyms] [k]
ia32_sysenter_target
a
0.83% quadEMTestApp [vdso] [.]
0xf77ac421
a
0.83% quadEMTestApp libpthread-2.14.1.so [.]
pthread_cond_wait
@@GLIBC_2.3.2
a
0.81% quadEMTestApp [kernel.kallsyms] [k] effective_load
-----Original Message-----
Sent: Monday, September 10, 2012 5:37 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: How to profile an EPICS application on Linux
On 9/10/12 5:21 PM, Mark Rivers wrote:
Here is the output of "time" when running it in a mode where "top"
showed the application using about 95% of a single CPU (on a 16
core system). This is with my calculations enabled.
23.547u 16.516s 0:52.39 76.4% 0+0k 0+24io 0pf+0w
This is the output of time when the calculations are disabled and
top shows about 80% CPU in my application.
Disabling my calculations:
11.401u 8.008s 0:27.60 70.2% 0+0k 0+8io 0pf+0w
So it spends a substantial amount of CPU time in both User Mode and
Kernel Mode.
Hi, Mark.
OK, then I don't know what's going on. Maybe gprof has problems
with threaded programs (??).
I'm really not answering your question now, but another idea: Is
your Linux system new enough that you have the perf subsystem
available? You could try that instead:
$ perf record ../../bin/linux-x86/quadEMTestApp
$ perf report
Lewis
- RE: How to profile an EPICS application on Linux Malitsky, Nikolay D
- How to profile an EPICS application on Linux Mark Rivers
- Re: How to profile an EPICS application on Linux J. Lewis Muir
- RE: How to profile an EPICS application on Linux Mark Rivers
Re: camonitor bug for string as array of chars Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
