1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: access record info from asyn
To: Tech Talk <[email protected]>
Date: Thu, 13 Sep 2012 08:44:26 +0200
I'm writing Asyn driver that will interface our application daemon running on Linux OS.
Application daemon is capable of emitting notifications that can tell the client (asyn) that there is a change in value. Asyn driver would register a callback to receive this notifications - everything is nice and running till now, assuming that record SCAN field is set to I/O Intr (camonitor refreshes value as expected).
How can I detect if user wants to change the SCAN field value to Passive? This would in turn mean that we need to unregister from the notifications that our application is sending and expect the user to do caget like access.
Thank you!
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
RE: access record info from asyn Mark Rivers
Prev: Re: font init failed Andrew Johnson
Next: waveform changes using subArray Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: access record info from asyn Mark Rivers
