Subject: waveform changes using subArray
To: Tech Talk <[email protected]>
Date: Thu, 13 Sep 2012 13:59:05 +0200
We are trying to support a modification of long array (i.e. more than 500 integer values) seen as a waveform in EPICS IOC. Lets say that it is possible and valid for user to change only one or two values from this array. By using waveform user needs to get all 500 integers locate the one she wants to change, do the modification, store complete array back. Using subArray to make a "window" into waveform sounded like a good solution, but as I just read in the docs, subArray does not support value writing back to the waveform.
Can this be done in some other manner? The goal here would be to allow user to get/see/change/set only the part of waveform, that shes interested in.
Thank you!
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
Re: waveform changes using subArray Hartman, Steven M.
Re: waveform changes using subArray Tim Mooney
Prev: access record info from asyn Hinko Kocevar
Next: RE: access record info from asyn Mark Rivers
Prev: Re: access record info from asyn Hinko Kocevar
Next: Re: waveform changes using subArray Hartman, Steven M.
