Subject: Re: waveform changes using subArray
To: Hinko Kocevar <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Thu, 13 Sep 2012 09:36:36 -0400
On Sep 13, 2012, at 7:59 AM, Hinko Kocevar wrote:
> Can this be done in some other manner? The goal here would be to allow
> user to get/see/change/set only the part of waveform, that shes
> interested in.
I did something similar a number of years ago to allow tuning of ramping waveforms. I used a subArray with a length of one element and an adjustable index into the array to inspect the elements, and an aoRecord to adjust that element for tuning. The aoRecord wrote to a genSub record which recalculated the waveform (recomputing the rest of the waveform based on the new input and smoothing around the changed element to avoid discontinuities). The genSub then populated the waveform output record which controlled the hardware. As I recall, I needed to do some tricks with DISV to control record processing (run mode versus tuning mode) and to sync the aoRecord with the waveform element when not in run mode.
Steven Hartman
[email protected]
Re: waveform changes using subArray Hinko Kocevar
Prev: Re: access record info from asyn Hinko Kocevar
Next: Re: waveform changes using subArray Hinko Kocevar
Prev: waveform changes using subArray Hinko Kocevar
