Subject: Re: waveform changes using subArray
To: Rod Nussbaumer <[email protected]>
Cc: [email protected]
Date: Mon, 17 Sep 2012 19:56:48 +0200
Hi Rod,
On 09/17/2012 06:28 PM, Rod Nussbaumer wrote:
I have used waveform records with device support to acquire data from
hardware, and then post-process the waveform data using a subroutine
record. The waveform .VAL is linked to an INPut link on the subroutine
record, and the waveform FLNK processes the subroutine record. The
subroutine record uses it's init function (specified in field 'INAM') to
locate the waveform record using dbGetPdbAddrFromLink(). I also connect
other waveform records that get written to as part of the subroutine
processing code ('SNAM'). This seems to work well for things like
stripping SCPI headers and converting odd numeric formats to
EPICS-friendly data types.
Yet another great solution.. it seems possibilities are endless, thats good.
At the start of development we've focused on the C part of the EPICS under the impression that this way we would have more control over how the data is processed and delivered. I must admit that DB part far neglected to some extent thus losing the ability to design powerful solutions using DB (and C). What we are trying to do is expose as EPICS PVs a very large set of parameters and data sources. The software that EPICS IOC will talk to (locally on a Linux host) and obtain data provides all parameter meta data. Things like name, type, size, ..
It is quite easy to get an EPICS record template and substitution files automatically generated from this meta data. Things get funky when trying to generate DB logic (not just 1:1 records). Also there is a natural expectation that IOC would be able to be used on several instruments in the family. That why automatism with certain extent of user intervention like custom configuration is an integral part of development.
Map data types like handling 64-bit (unsigned) integer or array of enumerated values to base EPICS record types becomes a challenge.
Another major development drive was performance. Every data copying saved is highly valued.
That being said and what we learned during the course of development I would say that more emphasis needs to put on DB part.
Hinko
Re: waveform changes using subArray Tim Mooney
Re: waveform changes using subArray Hinko Kocevar
Re: waveform changes using subArray Andrew Johnson
Re: waveform changes using subArray Rod Nussbaumer
Prev: Re: waveform changes using subArray Hinko Kocevar
Next: Re: waveform changes using subArray Andrew Johnson
Prev: Re: waveform changes using subArray Rod Nussbaumer
Next: StreamDevice release 2.6 Dirk Zimoch
