1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with using strings to access enum indices on Windows
Cc: "'Christian Schlepuetz'" <[email protected]>, "'[email protected]'" <[email protected]>, Peter Eng <[email protected]>, "'Sarvjit Shastri'" <[email protected]>, "'James Rezende Piton - LNLS'" <[email protected]>, "'Gerry Swislow'" <[email protected]>, "'Peter Kenesei'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Sep 2012 10:32:58 -0500
Hi Mark,
On 2012-09-23 Mark Rivers wrote:
> The problem is that the " %u %n" format string does not work on Windows.
> When I spoke to Andrew Johnson he said he thought this was because Windows
>  does not implement the %n format specifier.
> I have done some more investigation, and found that this is not the case.
>  The problem is the leading space before the %n specifier. On Windows when
>  sscanf hits the blank space in the format specifier, but does not find a
>  blank space in the input string, it stops parsing the input string. So it
>  never reaches the %n format specifier. The GNU run-time library behaves
>  differently, it processes %n even if there is no space in the input. I
>  think it is questionable as to which is the "correct" behavior.
Your further investigation reminded to check the Known Problems page; on
2012-01-26 I committed a change published a patch to R3.14.12.2 that removed
both spaces from the scanf() strings in dbConvert.c and dbFastLinkConv.c.  The
leading space in the format strings was never actually necessary, since the %u
skips leading spaces anyway.
Note that it is essential that we check for other characters that come after
the digits; for example consider setting the SCAN field of a record with the
string "5 seconds".  If we don't check that sscanf() consumes the whole string
then this could result in a 2-second scan period (there is no 's' on the end
of the official menu strings, so the choice string would not match).  That's
why the "%n" is an essential part of the format.  Using a "%u%n" format with
no space could break an existing application that relies on the numeric form
and happens to append a space or '\n' to its digits, but I thought this would
be fairly unlikely occur in reality.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Problem with using strings to access enum indices on Windows Mark Rivers
Prev: Re: Problem with using strings to access enum indices on Windows Eric Norum
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Next: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
