1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How can I collect data values
To: Kai Stein <[email protected]>
Cc: [email protected]
Date: Fri, 28 Sep 2012 09:34:39 +0200
Kai Stein wrote:
Hello,
I'm working on an automatic data analysis of electron beam (emittance measurement with a wire scanner and a magnetic lens) with EPICS. I get values from the hardware (self build measurement cards). The device support put the values into a longin records (this part is fixed, because it is already used for other applications). I need to gather the values (will be a position and a corresponding current) for a certain amount of time (approximately 1000 to 10000 values) and then hand it over to a subroutine, to perform the analysis (like fitting a curve onto the data). It should all run on a debian machine.
My problem is to collect the data with EPICS. I thought about collecting them somehow in a waveform record, but i have no idea, how to do this by using other records instead of the device support.
Best regards,
Kai Stein
If your longin processes once for each value "automatically", then the compress record is the easiest way. FLNK from the longin to the compress. (Or if that is not possible, use "CP" in the input link of the compress. But that will fail to fetch two consecutive samples with the same value.) Set NSAM to the maximum number of values you want to keep. You may set ALG="Circular Buffer". (If you want to average first, you may set N to the number of values that should be averaged into one sample value and set ALG="N to 1 Average".) After all values have been collected (you find the current filling in NUSE and can check it with a calcout record that you process with a FLNK from the compress) you can read VAL to get the array (probably filled up with 0 up to NSAM). Afterwards, write a 1 to RES to clear the array for the next measurement. The subroutine can be implemented in an aSub record (of if you have an older version of base with a genSub from SynApps).
If your longin does not process automatically but you have to trigger it and probably have to set other values in between two samples, then you should use the sscan record from SynApps.
Dirk
RE: How can I collect data values Hu, Yong
How can I collect data values Kai Stein
Prev: Loading modbus waveform record from acalcout record (or caput) jon
Next: camon: multiple servers found? Laznovsky Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How can I collect data values Mark Rivers
Next: RE: How can I collect data values Hu, Yong
