Subject: camon: multiple servers found?
To: <[email protected]>
Date: Fri, 28 Sep 2012 13:19:53 +0200
Title: camon: multiple servers found?
Hello- we're running a Tcl script which uses camon to get PV values for display, and
occasionally it spits out a message about "Identical process variable names on multiple
servers"... one of the listed servers is the correct CA gateway (EPICS 3.14.11), but the
other part is "Ignored: 0.0.0.1:5", which is not a valid address/port for anything.
Any ideas about what may be causing this?
See http://www.psi.ch/~laznovsky/tmp/finsb04-mcrx30_muliple_servers.png
thanks!
Mike
Re: camon: multiple servers found? Andrew Johnson
Prev: Re: How can I collect data values Dirk Zimoch
Next: problem passing string to aSub record parameter Jim Chen
Prev: Re: Loading modbus waveform record from acalcout record (or caput) Tim Mooney
Next: Re: camon: multiple servers found? Andrew Johnson
