Subject: Re: camon: multiple servers found?
To: [email protected]
Date: Fri, 28 Sep 2012 10:25:43 -0500
Hi Mike,
On 2012-09-28 Laznovsky Michael wrote:
> Hello- we're running a Tcl script which uses camon to get PV values for
> display, and
> occasionally it spits out a message about "Identical process variable
> names on multiple
> servers"... one of the listed servers is the correct CA gateway (EPICS
> 3.14.11), but the
> other part is "Ignored: 0.0.0.1:5", which is not a valid address/port
> for anything.
> Any ideas about what may be causing this?
> See http://www.psi.ch/~laznovsky/tmp/finsb04-mcrx30_muliple_servers.png
Are you sure that there isn't a second network route between this client and
server using an IP subnet 0.0.0.*?  Does the output from "ifconfig -a" on this
client machine show an interface to such a network?  It might be a private
administrative network that your IT group use.
You might want to take a look at your PV gateway's configuration of its
server-size addresses; if this is using a wildcard, try changing it to an
explicit list of addresses maybe.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: camon: multiple servers found? Laznovsky Michael
Prev: Re: problem passing string to aSub record parameter Andrew Johnson
Next: RE: problem passing string to aSub record parameter Jim Chen
Prev: camon: multiple servers found? Laznovsky Michael
Next: RE: camon: multiple servers found? Laznovsky Michael
