Hi Dirk- what do you make of Andrew's reply? The problematic pep
display is running
on finlc01:
2337 9320 9319 0 Aug13 pts/23 00:25:25 wish /fin/devl/bin/pep
FIN-M-CP10W.prc
Mike
-----Original Message-----
Sent: Freitag, 28. September 2012 17:26
To: [email protected]
Cc: Laznovsky Michael
Subject: Re: camon: multiple servers found?
Hi Mike,
On 2012-09-28 Laznovsky Michael wrote:
> Hello- we're running a Tcl script which uses camon to get PV values
for
> display, and
> occasionally it spits out a message about "Identical process variable
> names on multiple
> servers"... one of the listed servers is the correct CA gateway (EPICS
> 3.14.11), but the
> other part is "Ignored: 0.0.0.1:5", which is not a valid address/port
> for anything.
> Any ideas about what may be causing this?
> See
http://www.psi.ch/~laznovsky/tmp/finsb04-mcrx30_muliple_servers.png
Are you sure that there isn't a second network route between this client
and
server using an IP subnet 0.0.0.*? Does the output from "ifconfig -a"
on this
client machine show an interface to such a network? It might be a
private
administrative network that your IT group use.
You might want to take a look at your PV gateway's configuration of its
server-size addresses; if this is using a wildcard, try changing it to
an
explicit list of addresses maybe.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: camon: multiple servers found? Laznovsky Michael
- camon: multiple servers found? Laznovsky Michael
- Re: camon: multiple servers found? Andrew Johnson
Re: Loading modbus waveform record from acalcout record (or caput) jon
<2012>
2025
2026
<2012>
2025
2026
