Subject: Re: Loading modbus waveform record from acalcout record (or caput)
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Fri, 28 Sep 2012 16:54:37 -0700 (PDT)
Thanks - this worked.  I used PP NMS.  Also, I changed OOPT from "On Change" to "Every Time" -- thanks for spotting that, I think it was needed.
Regarding efficiency of acalcout vs gensub, we don't expect performance problems, but if we see any, we can revert.   Using just the standard EPICS record types does simplify things a bit.
Jon Jacky, University of Washington
On Fri, 28 Sep 2012, Tim Mooney wrote:
Jon,
field(OUT, "CnOutWArray.VAL CA NMS")
and
field(OUT, "CnOutWArray.VAL PP NMS")
should both work.
The "caput -a..." command you show is not succeeding in setting the array elements because of the commas.
$ caput -a CnOutWArray 28 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
should work, and verify that the waveform record is accepting puts.
Re: Loading modbus waveform record from acalcout record (or caput) Tim Mooney
Prev: Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
Next: RE: camon: multiple servers found? Laznovsky Michael
Prev: Re: Loading modbus waveform record from acalcout record (or caput) Tim Mooney
Next: Re: Loading modbus waveform record from acalcout record (or caput) Tim Mooney
