1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem passing string to aSub record parameter
To: "Jim Chen" <[email protected]>
Cc: [email protected]
Date: Fri, 28 Sep 2012 11:06:29 -0500
Hi Jim,
On 2012-09-28 Jim Chen wrote:
> The problem is that I need to retrieve this string in the aSub Init
> routine, as it states here: field(INAM,"myfunctionInit"). At that point,
> the stringout record might not be processed yet.
It doesn't need to be processed, its VAL field already holds the string that
you want.  The issue you're having though is that the aSub record doesn't read
its input links before calling your init() subroutine, so you can't expect to
see a value in prec->a until your process() subroutine gets called later.
> I suppose the PP key is
> to force the other record to be processed afterwards. Even when I set the
> stringout record PINI=1, and place it before my aSub record. This comes to
> another question, what is the order when the database records are read and
> initialised?
The order of initialization of records at iocInit() is not documented, so it
can change in the future.  Currently all records of one type get initialized
together before moving onto the next type, and the order of the record types
is controlled by their order in the DBD file that the IOC loads.  Within each
record type it looks like the records will get initialized in alphabetical
order, using strcmp() to determine that order, but I wouldn't rely on that
staying the same for ever.  All records get initialized before any get
processed though.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
problem passing string to aSub record parameter Jim Chen
Re: problem passing string to aSub record parameter Andrew Johnson
RE: problem passing string to aSub record parameter Jim Chen
Prev: RE: problem passing string to aSub record parameter Jim Chen
Next: Re: Loading modbus waveform record from acalcout record (or caput) Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Recall: problem passing string to aSub record parameter Jim Chen
