I have an AO record whose ALST & MLST are stuck at nan:
$ caget KLYS:LI23:81:PJTN KLYS:LI23:81:PJTN.PVAL KLYS:LI23:81:PJTN.LALM KLYS:LI23:81:PJTN.ALST KLYS:LI23:81:PJTN.MLST KLYS:LI23:81:PJTN.ADEL KLYS:LI23:81:PJTN.MDEL KLYS:LI25:81:PJTN KLYS:LI25:81:PJTN.PVAL KLYS:LI25:81:PJTN.LALM KLYS:LI25:81:PJTN.ALST KLYS:LI25:81:PJTN.MLST KLYS:LI25:81:PJTN.ADEL KLYS:LI25:81:PJTN.MDEL
KLYS:LI23:81:PJTN 0.164428
KLYS:LI23:81:PJTN.PVAL 0.164428
KLYS:LI23:81:PJTN.LALM 0.164428
KLYS:LI23:81:PJTN.ALST nan
KLYS:LI23:81:PJTN.MLST nan
KLYS:LI23:81:PJTN.ADEL 0
KLYS:LI23:81:PJTN.MDEL 0
KLYS:LI25:81:PJTN 0.0761155
KLYS:LI25:81:PJTN.PVAL 0.0761155
KLYS:LI25:81:PJTN.LALM 0.0761155
KLYS:LI25:81:PJTN.ALST 0.0761155
KLYS:LI25:81:PJTN.MLST 0.0761155
KLYS:LI25:81:PJTN.ADEL 0
KLYS:LI25:81:PJTN.MDEL 0
Once ADEL is stuck at nan, the AO record support has no way to clear this. From aoRecord.c:
/* check for archive change */
delta = prec->alst - prec->val;
if(delta<0.0) delta = -delta;
if (delta > prec->adel) {
/* post events on value field for archive change */
monitor_mask |= DBE_LOG;
/* update last archive value monitored */
prec->alst = prec->val;
According to Matjaz Kobal, COSYLAB, "Every arithmetic expression that includes a NAN value will have a NAN value as a result. So "delta" will have a value of NAN. Also every comparison with a NAN value will return false. So none of the two if statements will execute their bodies and the monitor_mask will not change. Since the ALST field value is not changed anywhere else, there is no way to get inside the if statement."
I have not verified the above statement, but I believe it to be true.
Q1: Have you ever seen this? If you have, how did you overcome it?
My testing tells me ALST doesn't get set to nan when VAL goes to nan. Example:
lcls-zelazny bash:~>caget SIOC:SYS0:ML02:AO201 SIOC:SYS0:ML02:AO201.ALST SIOC:SYS0:ML02:AO201.MLST
SIOC:SYS0:ML02:AO201 0
SIOC:SYS0:ML02:AO201.ALST 0
SIOC:SYS0:ML02:AO201.MLST 0
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 1
Old : SIOC:SYS0:ML02:AO201 0
New : SIOC:SYS0:ML02:AO201 1
SIOC:SYS0:ML02:AO201.ALST 1
SIOC:SYS0:ML02:AO201.MLST 1
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 nan
Old : SIOC:SYS0:ML02:AO201 1
New : SIOC:SYS0:ML02:AO201 nan
Old : SIOC:SYS0:ML02:AO201 nan
lcls-zelazny bash:~>caput SIOC:SYS0:ML02:AO201 2
New : SIOC:SYS0:ML02:AO201 2
SIOC:SYS0:ML02:AO201.ALST 2
SIOC:SYS0:ML02:AO201.MLST 2
lcls-zelazny bash:~>caget SIOC:SYS0:ML02:AO201.ADEL SIOC:SYS0:ML02:AO201.MDEL
SIOC:SYS0:ML02:AO201.ADEL 0
SIOC:SYS0:ML02:AO201.MDEL 0
Q2: Any idea HOW my ALST & MLST got nan?
I'm running a soft IOC on RHEL5 with EPICS 3.14.12.
I'm tempted to change the code to:
if ((epicsNAN == delta) || (delta > prec->adel)) {
Q3: Is there any reason I shouldn't?
Thanks in advance for your help!
Mike
- Re: AO ALST & MLST stuck at nan. Andrew Johnson
Lambda-TDK Genesys support Jiro Fujita
Re: Announcing pymsi - EPICS macro substitution and expansion tool Angus Gratton
<2012>
2025
2026
RE: Lambda-TDK Genesys support Szalata, Zenon M.
<2012>
2025
2026
