Hi Mike,
On 2012-10-04 Zelazny, Michael Stanley wrote:
> I have an AO record whose ALST & MLST are stuck at nan:
Interesting, that would appear to be a bug...
> According to Matjaz Kobal, COSYLAB, "Every arithmetic expression that
> includes a NAN value will have a NAN value as a result. So "delta" will
> have a value of NAN. Also every comparison with a NAN value will return
> false. So none of the two if statements will execute their bodies and the
> monitor_mask will not change. Since the ALST field value is not changed
> anywhere else, there is no way to get inside the if statement."
> I have not verified the above statement, but I believe it to be true.
Pretty much.
> Q1: Have you ever seen this? If you have, how did you overcome it?
No.
> Q2: Any idea HOW my ALST & MLST got nan?
Well ALST and MLST get set from the VAL field at record initialization time,
so the NAN could have come in that way.
> I'm tempted to change the code to:
> if ((epicsNAN == delta) || (delta > prec->adel)) {
> /* post events on value field for archive change */
> monitor_mask |= DBE_LOG;
> /* update last archive value monitored */
> prec->alst = prec->val;
> Q3: Is there any reason I shouldn't?
Yes, because it won't work, (epicsNAN == epicsNAN) returns false (see Matjaz's
statement above). There have been bugs reported in more than one C compiler
optimizer when their author assumed that x==x is always true. Much better is
to change the sense of the conditional so the comparison with NAN returning
false triggers the if statement:
if (!(delta <= prec->adel)) { /* handle NAN properly */
I would think a similar change should be made to quite a few record types in
Base (if anyone gets there before I do please send me a patch file...).
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: AO ALST & MLST stuck at nan. Zelazny, Michael Stanley
- AO ALST & MLST stuck at nan. Zelazny, Michael Stanley
Re: Announcing pymsi - EPICS macro substitution and expansion tool Angus Gratton
RE: Lambda-TDK Genesys support Allison, Stephanie
<2012>
2025
2026
<2012>
2025
2026
