1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: waveform EDM widget
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 Oct 2012 08:30:44 -0400
On 10/5/12 08:00 , "Hinko Kocevar" <[email protected]> wrote:
>Hi,
>I one would have an array of strings saved in a waveform record
>(FTVL=STRING), which (M)EDM or CSS widget would be appropriate to
>display and edit the data?
>Also which widgets would be utilized in combination with waveform record
>that has other types (LONG, FLOAT, ..).
CSS BOY has array support.
You can _display_ numeric waveforms as a trace in a plot.
There's also an array widget wrapper that allows you to for example assign
a "slider" to each array element for editing them, see
http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/
tip/applications/plugins/org.csstudio.opibuilder/html/ChangeLog.html
-Kay
Re: waveform EDM widget Hinko Kocevar
Prev: waveform EDM widget Hinko Kocevar
Next: EPICS 3.15.0 incompatible make rules Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: waveform EDM widget Hinko Kocevar
