1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Triggered autosave on exit
To: Yong Hu <[email protected]>
Cc: "[email protected] talk" <[email protected]>
Date: Fri, 5 Oct 2012 10:06:10 -0700
The ALS uses a sub record:
record(sub,"$(IOC):exit") {
        field(DESC,"Exit subroutine")
        field(SCAN,"Passive")
        field(SNAM,"exitSubroutine")
with:
static void exitSubroutine(subRecord *precord) {
    epicsExit((precord->a == 0.0) ? EXIT_SUCCESS : EXIT_FAILURE);
epicsRegisterFunction (exitSubroutine);
Processing this causes the IOC to exit.
On Oct 5, 2012, at 9:42 AM, "Hu, Yong" <[email protected]> wrote:
> Franck's use case of the autosave is very interesting, but I guess it may take efforts to find the solution. I have tried different ways on Linux softioc:
> 1. I tried to add manual_save() to the xxxMain.cpp. Something like these:
>    iocsh(NULL);
>    manual_save("xxx.req");
>    epicsThreadSleep(2);
>    epicsExit(0);
> However, this will not work since manual_save() is only available in the autosave module and it is not included in the EPICS base.
> 2. I tried to use create_triggered_set() in the startup script file (st.cmd) just as Tim's suggestion. Also I used the devIocStats module which provides a PV named "yhuHost:SYSRESET" to reboot the IOC. Here are the configurations for st.cmd and db file:
> st.cmd:
>    create_monitor_set("auto_settings.req",30,"P=xxx:")
>    create_triggered_set("auto_settings.req","yhuHost:resetIOC","P=xxx:")
> db file:
>    record(bo,"yhuHost:resetIOC")
>        field(ZNAM,"NoRest")
>        field(ONAM,"Reset")
>        field(FLNK,"yhuHost:seqExample")
>    record(seq,"yhuHost:seqExample")
> 	  #delay 2 seconds to reboot the IOC
>        field(DLY1,"2")
>        field(LNK1,"yhuHost:SYSRESET.PROC ")
> When I do "caput yhuHost:resetIOC 1", the autosave is really executed (the save file "auto_settings.save" is written) and then about 2 seconds later, there is a message output "IOC reboot started" from the softioc. However, the IOC is not really rebooted, it is hung up (I still see the Shell "epics>").
> Any suggestion about my second approach? Any other better way?
> Thanks,
> Yong
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: Friday, October 05, 2012 10:42 AM
> To: Tim Mooney; Di Maio Franck
> Cc: [email protected]
> Subject: RE: Triggered autosave on exit
> Can I have a PV that does that when I type "exit" on my softIoc?
> I agree that what Frank suggests would be very nice.
> Mark
Eric Norum
[email protected]
Triggered autosave on exit Di Maio Franck
Re: Triggered autosave on exit Tim Mooney
RE: Triggered autosave on exit Mark Rivers
RE: Triggered autosave on exit Hu, Yong
Prev: RE: Triggered autosave on exit Hu, Yong
Next: RE: Lambda-TDK Genesys support Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Triggered autosave on exit Tim Mooney
