Hi Janet,
How is it going?
For IOC Application deployment; I would like to take advantage
of the $(INSTALL LOCATION).
The only problem is that IOC Startup files do not get installed
along with other products such as databases, libraries, etc...
So, I tried to do something like the following:
In my $IOC_APP_TOP/iocBoot/<iocName>
Create CONFIG_STARTUP:
============ CONFIG_STARTUP
FILE_TYPE
+= STARTUP
INSTALL_EDL = $(INSTALL_LOCATION)/ioc/vioc-b34-cd39
Add to Makefile:
========== Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
# Config for installing IOC startup related files:
CFG += CONFIG_STARTUP
ARCH =
linuxRT-x86
TARGETS = envPaths
INSTALL_STARTUP += envPaths rtPrioritySetup.cmd st.cmd
include $(TOP)/configure/RULES
include
$(TOP)/configure/RULES.ioc
The above does not work.
[ernesto@cdlx01 vioc-b34-cd39]$ make
/afs/slac/g/lcls/epics/base/base-R3-14-12/configure/RULES_DIRS:72:
*** target file `clean' has both : and :: entries. Stop.
Can you recommend a way to achieve this in the context of the
EPICS Make/Build system?
Cheers,
Ernest
- Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Ralph Lange
Re: CSR/CR questions Bjorklund, Eric A
Re: waveform record: how its VAL get data? any potential memory leak? ... Jack Smith
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
