Subject: |
Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 01 Nov 2012 16:12:31 +0100 |
Hi Ernest,
the main issue behind this:
In the traditional EPICS build system, IOC startup files (actually
everything under iocBoot) are considered source files. Other than
for libraries, databases etc., these sources are not compiled in
any way, and they do not create any products that are installed.
Without an installation step, $(INSTALL_LOCATION) does not apply.
For our HZB/BESSY developments, we are creating the startup files
programmatically in an ...App directory, so we changed our rules
to treat .../iocBoot as an installation directory (much like lib,
bin, ...), and install the created startup scripts there. In this
setting, there is an installation step for these files, and
$(INSTALL_LOCATION) works as expected.
Trying to select the relevant configuration parts....
Our CONFIG contains:
INSTALL_BOOT := $(INSTALL_LOCATION)/iocBoot
UNINSTALL_DIRS += $(INSTALL_BOOT)
The ...App Makefile uses this by setting:
IOCS = $( /* database call to get ioc names */ )
STCMD_INSTALLS = $(IOCS:%=$(INSTALL_BOOT)/ioc%/st.cmd)
build: $(STCMD_INSTALLS)
$(STCMD_INSTALLS): $(INSTALL_BOOT)/ioc%/st.cmd:
$(COMMON_DIR)/st.cmd.%
@echo "Installing $@"
@$(CP) $< st.cmd
@$(INSTALL) -d -m 644 st.cmd $(@D)
@$(RM) st.cmd
$(COMMON_DIR)/st.cmd.%: ../%.st.cmd
@$(CP) $< $@
Hope this shows the general direction...
Cheers,
~Ralph
On 30.10.2012 16:51, Ernest L. Williams Jr. wrote:
Hi
Janet,
How is it going?
For IOC Application deployment; I would like to take advantage
of the $(INSTALL LOCATION).
The only problem is that IOC Startup files do not get
installed along with other products such as databases,
libraries, etc...
So, I tried to do something like the following:
In my $IOC_APP_TOP/iocBoot/<iocName>
Create CONFIG_STARTUP:
============ CONFIG_STARTUP
FILE_TYPE
+= STARTUP
INSTALL_EDL = $(INSTALL_LOCATION)/ioc/vioc-b34-cd39
Add to Makefile:
========== Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
# Config for installing IOC startup related files:
CFG += CONFIG_STARTUP
ARCH =
linuxRT-x86
TARGETS = envPaths
INSTALL_STARTUP += envPaths rtPrioritySetup.cmd st.cmd
include $(TOP)/configure/RULES
include
$(TOP)/configure/RULES.ioc
The above does not work.
[ernesto@cdlx01 vioc-b34-cd39]$ make
/afs/slac/g/lcls/epics/base/base-R3-14-12/configure/RULES_DIRS:72:
*** target file `clean' has both : and :: entries. Stop.
Can you recommend a way to achieve this in the context of the
EPICS Make/Build system?
Cheers,
Ernest
- RE: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Williams Jr., Ernest L.
- User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Ernest L. Williams Jr.
RE: Runaway connection count on IOC -- Possible Gateway Issue? michael.abbott
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
