1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using CSS data browser
To: Pavel Maslov <[email protected]>
Date: Mon, 5 Nov 2012 15:20:13 -0500
Looks familiar enough.  Thanks!
James
On Mon, Nov 5, 2012 at 3:15 PM, Pavel Maslov <[email protected]> wrote:
Just off the top of my head, I think so.
You will also need to compile another application - archive config tool. It's a headless Eclipse application. This is how the xml file may look like:
  <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
 Created by ArchiveConfigTool -engine linu -export
     2012/01/17 17:13:08.906000000
- <engineconfig>
- <group>
  <name>chh 1</name>
- <channel>
  <name>rootHost:ai1</name>
  <period>0.5</period>
  <monitor />
  </channel>
  </group>
- <group>
  <name>chh 2</name>
- <channel>
  <name>rootHost:ai2</name>
  <monitor />
  </channel>
  </group>
  </engineconfig>
On Mon, Nov 5, 2012 at 9:06 PM, James F Ross <[email protected]> wrote:
Actually I managed to find it just a moment ago.  It's under Edit -> Preferences -> CSS Applications -> Trends -> Data Browser -> Default Archive Data Sources.  I think it's just a preferences thing with no need to recompile, but we'll see.
I likely will want to use the relational database archiver, but I'll likely need to get that going first, assuming it is separate from CSS (I'm rather new at CSS and any EPICS archiver).  We are currently using the old channel access archiver and the archive viewer to view the databases.
For the moment, I'm simply trying to get the data browser to view the old archive in place of the archive viewer.
I do have a question though on the relational database archiver.  Does the RDB archiver use a similar setup to the channel access archiver?  That is, does it still use .xml files as index files to tell the archiver when and how to monitor EPICS channels?
Thanks for your help!
James
On Mon, Nov 5, 2012 at 2:49 PM, Pavel Maslov <[email protected]> wrote:
Hey James,
In case you'd like to use BEAUTY and BEAST as the archiving system and alarm system respectively, you'd have to edit the source code in Eclipse RCP, then compile everything (CSS, Archive server, Alarm server). But I guess, if you know the address of the relational database, login and password, you can adjust it in the Preferences.
Or do you wish to use another archiver I'm completely ignorant of?
On Mon, Nov 5, 2012 at 8:34 PM, James F Ross <[email protected]> wrote:
Hello everyone,
I've downloaded CSS for use at STAR.  I hope to replace the old channel archiver and use the data browser instead, but I'm having trouble getting it to work.  I downloaded the NSLSII version since they are located at Brookhaven National Lab as well but it came preconfigured for their setup.  Specifically, when I start it up it automatically tries to load ArchiveDataServer.cgi from their location.  I know where this file is located on our machine, but I need to know how to change this path, as well as any other NSLSII specific settings.  Can this be configured from the workspace or do I have to do it somewhere in the source code?
Thanks a lot!
James Ross
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
using CSS data browser James F Ross
Re: using CSS data browser Pavel Maslov
Re: using CSS data browser James F Ross
Prev: Re: using CSS data browser Pavel Maslov
Next: Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: using CSS data browser Kasemir, Kay
