Subject: Re: Problems sending \x0 with devGpib driver
To: Eric Norum <[email protected]>
Cc: "[email protected] talk" <[email protected]>
Date: Fri, 09 Nov 2012 14:29:13 +0100
On 08.11.2012 18:02, Eric Norum wrote:
Although not directly related to this thread, an issue I've encountered when attempting to write StreamDevice support for devices with "esoteric" command/reply formats is the inability to provide a custom conversion routine as provided by devGpib.
I went digging through my (very) old e-mail messages and recovered this one proposing an addition to StreamDevice that would allow for user-supplied conversion code.  It's still not quite as general a solution as that provided by the devGpib GPIBCVTIO support but it does allow for message format conversions beyond those provided by StreamDevice.
Perhaps others might find this useful enough that it could be made part of the StreamDevice distribution.
New format string modifier<function_name>.  For example,
      %<function_name>ld
      %<function_name>f
      %<function_name>lf
Where function_name is the name of a conversion function [...]
Hi Eric
This is quite similar to the checksum functions I already have implemented, and which use the %<...> format. And if I remember correctly, this was indeed based on your ideas.
Maybe I can modify this a bit in order to allow general user supplied functions. Checksums would then be a part of the user function model.
I have to think about this and play a bit.
Escaping to user code is of course always "dangerous". You never know how much stack the call uses, if it blocks, if it throws exceptions etc.
Dirk
Problems sending \x0 with devGpib driver Andrew Wagner
Re: Problems sending \x0 with devGpib driver Eric Norum
Re: Problems sending \x0 with devGpib driver Andrew Wagner
Re: Problems sending \x0 with devGpib driver Dirk Zimoch
Prev: Re: compile EPICS base on Mac OS (Snow Leopard) using GCC from macport Shen, Guobao
Next: Linkam temperature controller CI94 serial programming 洪春霞
Prev: Re: Problems sending \x0 with devGpib driver Eric Norum
Next: EPICS Collaboration Meeting October 2012 : Update Ilyou Kim
